- Year
- 2008
- Vehicle Model
- 200 Series
- Location
- Array
- Mileage
- 272001
- Color
- White
I envisioned this truck to be a UN replica or GCC spec 200 series.
It's well taken care of and was maintained regularly. This truck spent majority of its time in Texas with only a few months in IL - It's a rust free truck.
Truck can be driven anywhere, fly & drive or I can arrange a transport.
Body/Cosmetics:
Thanks for reading. PM with any questions, happy to discuss.
Truck is sold. Thanks everyone for showing interest!
- 2008 Toyota Land Cruiser ordered through Gulf States Toyota
- Clean Carfax, no accidents - 2 owners prior to me
- No check engine lights or warning lights
- 272XXX miles
- No cool box, No headlight washers & All leather steering wheel
- Factory remote start
- My understanding is there's a very low number of these with this configuration.
- Does have a rear entertainment center, which I believe was port installed or dealer installed
- Fluids/Routine Service:
- Synthetic oil change w/ OEM filter
- Transmission Fluid replaced w/ Toyota World Standard ATF
- Power Steering Fluid replaced w/ Toyota PS Fluid
- Brake Fluid replaced w/ Toyota DOT 3
- Front & Rear diff fluid replaced with Valvoline gear oil
- Coolant system flushed with SLLC (Super Long Life Coolant)
- Driveshaft greased
- Cabin Filter & Engine Air Filter Replaced
- New headlight bulbs High/Low Beam
- Recent work
- Front Brake Rotors & Pads replaced with OEM
- OEM Battery
- PCV valve replaced (OEM)
- MAF Sensor replaced (OEM)
- Transmission Cooler & Transmission Thermostat replaced
- Factory suspension refresh thanks to @Eric Sarjeant
- Front & rear shocks replaced
- Front OEM Spacer installed
- Front & rear springs replaced
- Front UCA's replaced
- KDSS adjustment & alignment
- Other work done by previous owner:
- Both Catalytic convertors were replaced with OEM ones ~12 months ago at a Toyota dealership
- Transfer case was replaced in August 2023 (PO said 4LO & Center diff light kept flashing) - Everything functions fine & as it should now
- Starter was replaced at the same time as the Tcase
Body/Cosmetics:
- 17x7 Toyota OEM steel wheels w/matching spare & TPMS
- New Michelin Defender tires LTX MS tires (awesome tire)
- Fog light delete (OEM)
- Roof rack delete (OEM)
- New OEM headlights
- Painted grill w/ new sombrero
