Hi all,
I lurk more than I actually post. I figured I would have more relevant feedback and help from the "early cruiser group" regarding my ignition switch for my March 1972 FJ40.
Here's the scenario:
I parked my cruiser for the night after a 20 minute drive on the freeway. Then I came back to start it up so I could park it in the backyard. I was able to start the Cruiser with no issues, but the engine would die as soon the key turned to ON. I thought maybe a vacuum hose or my ignition idle wire broke (since I just finished repairing it the previous week). I found everything to be intact under the hood, so I decided to leave it for the night.
Today: I found time to tackle the issue. I disconnected the battery ground, before touching anything under the dash. Took a glance at my fuses and found them all to be in good order. I removed the retaining ring and pushed the ignition switch through the dash wall. I found the (fig. 1/2) the Black-Red wire to be discoloured and burnt at the plug.
When I removed the ignition switch I found the AM blade on the switch to be loose at the copper rivet (fig. 3/4).
My question is, what could have caused this in the first place? I can quite safely say that my wiring is all original, unmolested and in excellent repair for being 39 years old.
Then my next question stems from my purist approach to things. I was curious if I could retain my original key tumbler when replacing the ignition switch (part # 84450-60040). Has anyone here done this before? Any recommendations? There is one set screw on the side of the switch, (fig. 5) if I remove it, can I pull the tumbler out?
Thank you for your help!
FIG. 1
FIG. 2
FIG. 3
FIG. 4
FIG. 5
FIG. 1
FIG. 2
FIG. 3
FIG. 4
FIG. 5
