Wanted to share my experience with the broken ignition camshaft to hopefully save someone else the problems I ran into. First lesson learned was to read the entire thread and don't skim as I did.
The ignition shaft broke of course at the most inopportune time, why wouldn't it!!!
Saw some part numbers on this thread and then went to one of the many online toyota part retails to get the part number listed. The part number the site came up with for a 2001 cruiser was a 45280-60510 which I have seen on this thread. Purchased this ignition housing assembly from a local Toyota deal who could have it for me the next day. As mentioned you can not just buy the camshaft unless you try your luck on ebay.
So I purchased the 45280-60510 as the online search only provide this PN as an option. Went and picked up the part the next day from Toyota and came home to remove the camshaft as I didn't want to the mess with replacing the entire assembly. When I pulled the camshaft out of the assembly it did look a bit different in design from the removed broken unit, sorry didn't take a picture. Anyway, installed the new camshaft in the installed original housing and reinstalled the ignition switch. I proceeded to install the lock assembly and knew something was wrong because when I turned the ignition to start, nothing happening and the key wouldn't turn all the way off in order to removal of the key. So I pulled the camshaft back out and compared it against the broken one. The camshaft from the replacement assembly I just purchased for $280.00 appeared to have about a 1-2 degree rear shaft to ignition switch alignment difference from the broken one which doesn't indicate the correct position to the ignition switch.
So after fully reading this thread I see there was mention of a ignition housing assembly for a electronic tilt steering column and a manual steering column. The camshaft from PN housing assembly 45280-60510 (electronic tilt application) ignition housing assembly will not work in a manual tilt PN 45280-60460 ignition housing assembly. Not only are the camshafts different between the two assemblies, the housings themselves have different ignition switch index notches built into the metal housing. My guess is if you were to install the electronic tilt PN 45280-60510 into a manual tilt vehicle as well as change the plastic ignition switch, this should work although much more work than just replacing the camshaft.
Anyhow, two different assemblies- #1. for a electronic tilt steering column 45280-60510 and #2. for a manual tilt steering column 45280-60460. The Camshafts between the two are not interchangeable. Don't make the same mistake as I did and get the correct part for your application. If you don't know call your local Toyota dealer and provide them the VIN number when you order the part with them, I did not do this and gave the dealer the PN I though I knew to be correct.
