FJBen said:just bored here...but how do you figure 16" of rear wheel travel...just trying to figure it out, not start a pissing contest.
"Shock travel" does not equal "wheel travel" which also does not equal "articulation".
Measured from compression to full extension the rear travel was over 16-inches.
This makes sense because my standard OME 100 was just over 13-inches. I've added 2.6" more extension. More is available with a 33" tire due to lesser bump-stop requirements.
The actual "articulation" spec is much greater. I believe in the 25-26" range...same as an L-shocked 80-series.
. On your rear axle you will not have more travel than the shock travel itself. You will have more articulation, but not more travel. WHen you drive over dunes or dessert washboard roads articulation means very little, but up down travel is the name of the game. And you actually prefer stiffer shocks and springs to keep from bottoming or topping out.
