Slight update on this..... Brian will be installing new starter and new HD cables sometime next week, as well as getting fuel pressure numbers and compression numbers for me. Anyone that wants to help get with
@GarnerFJ40 to see when he is doing it. He will also be doing some work on his black 80 and running a few tests on the OM616 he has for the 55. If people show up to work i'll shoot Brian some more cash to buy food and beer for workers. @lumbee1 you had asked so just letting you know.
i've been talking to a bunch of people that have done 2fe builds, turbo builds on 3fe and a couple local LC guru's. I'm getting a spare 3fe head to start building with bigger better valves and get the intake manifold, exhaust manifold, head and TB ported, polished, bored what ever you want to call it. I have all the spare manifolds here I think in a box in storage.
Still reading through a lot of threads..... realistically the 3fe can make quite a bit of power. Its real limitation is the early untunable efi ecu. The chevy straight 6's that it is essentially based on can be made into power houses. But I am still aiming to use the stock ecu with the rising rate FPR and an extra injector in place of the cold start that fires once a certain boost is attained if needed. My ultimate goal down the line with this motor needs it to be pretty plug and play.
