Since my spreadsheet contains 15 years of proprietary information from my shop, I prefer to go through how anyone else can set up a spreadsheet.
On this list, there is plenty of data that gives psi boost > Hp figures from TRD. There is also the known of 212 at 4350 from toyota. From this data, you can assign air and fuel in CFM, lbs/hr, lbs/min, lbs/sec or any other. You have a lot of knowns (engine sudoku) that can fill in some of the unknowns, like injector size and known hp and torque figures at a variety of boost levels. What you end up with is a 'factor' for air and fuel vs horsepower estimation.
I'm convinced a SWAG factor can be calculated much simpler, and it really doesn't matter which one you choose. Get one, and back the math up to confirm toyotas dyno numbers, then plug the 2lbs of air back in. The MAF mod doesn't give a HP factor of 10, period.
For the nerds on this list up to the challenge, I used VE of 100% at peak torque and 85% at peak HP for the 4477cc I6. I also used 'rolling ramp' lambda number of 1.00 at 1000rpm, .86 for peak torque and .88 for peak HP.
You can take any 'change' and come up with a revised horsepower estimation (the factor is a a relative constant). Or, in the case of Rick giving only a number for air with no unit... I divided my existing normally aspirated lb/hr column by 60 and determined that the unit Rick was measuring was lb/min and that at "21+"(lb/min), it was at peak HP. I could go back and correct to vacuum, but 99% of my time on these spreadsheets is in boost. What I can do, is give Rick the benefit that his mod caused a .5psi pressure increase (= vacuum drop across the MAF) on a Normally Aspirated truck and get the same "23+"(lb/min) he measured at ~4300rpm. That gives a MAF mod HP increase of F4, all else being equal.
I originally made up this spreadsheet for fuel, not air, but it appears to confirm toyotas published numbers, and defined the undefined OBDII unit in the air reading Rick put up. It also shows not much real gain in HP when calculated out. That's not to say that throttle response isn't better, or that driveability isn't better, only that gains in HP is tough to realize on a MAF change in a Normally Aspirated truck with no other mods.
My experience in dyno numbers, as well as the spreadsheet I used, lead me to propose that a HP factor of 10 for a MAF seems optimistic, since there is no real volumetric increase in the engine. Put pressure into the intake, things might be different. Isolating this on the dyno is simpler for those wanting to make the claim of HP=F10 without the math. My spreadsheets only *predict* dyno numbers based on the knowns of the 1FEFZ engine.
Your resident 1FEFZ nerd
Scott Justusson
