- Thread starter
- #21
Nice set up-
Interested to know your post lift, post Nitro UCA install alignment numbers- especially your caster numbers.
I don't recall the post-alignment numbers. I will see if I can find them.
Nice set up-
Looks great and I have only heard positive feedback about Icon. Looking forward to desert testing report.
It your rear springs are that loose at full droop you will want to address it ASAP. In an emergency situation you can loose your spring and bad things can happen, I have seen it first hand. Super easy to address without need of special tools. If you go with the way I did it the hole is already in the lower perch add a bent piece of strap and you will be good to.
So you are supposed to mount the reservoir on the outside of the frame - you should need a heat shield. I didn't see if you posted but is there a reason you put it on the inside? Mine are mounted on the outside on both sides.
I had mounted them outside the frame towards the back. It looked great! the only problem was once I went wheeling and was going to do some real flexing, it was too late when I noticed the sway bar was pulling on the lines and damaged my rear shocks.. They are at icon being rebuilt or replaced right now..... it going to cost me somewhere between $3-500..... A lesson well learned...... I am currently struggling with the front mounting system. I have the resi mounted the frame, horizontally. Again, very visual pleasing, however when the wheel is fully turned and compressed, the tire rubs the resi. I think I will need to mount it vertically.
Hayes - What was the total cost for the Icon's and UCA's? Been contemplating upgrading from my OME's to either Icon's or King's.
Thanks
Great, thanks. Roughly the same as King's and believe quality, reliability, etc. is about the same as well. I think you said that the stage 3's are adjustable? Did you make any adjustments for your Moab trip and did you notice any difference?
After your icon install, did you adjust your T-bars?The icon stage 3 shocks are well worth it. If you can afford it, do it! A byproduct of the shocks I did not think about was the extended travel. With my Old man EMU shocks, I had my front torsion bars jacked to make my truck level and there wasn't any down travel. It was kind of a rough ride. As soon as I installed my icons, the ride improved dramatically, but I also wasn't maxing out the down travel of my front suspension anymore.
Still have the $13k unspent from the sale of my beloved 80 series earlier this year. Regarding the torsion bars, I had the same problem and recently adjusted them with a buddy of mine to lower the front end a bit as the ride was INSANELY hard. A little better but still hard, partly due to the heavy OME springs in the rear. I'm glad to hear that the Icon's made a different on the ride, and of course with that price, they'd better.![]()
Slinkys: very interested in these. Reminds me of the parabolic springs for the 60's, but with better vendor support
Question: can one run airbags with the slinkys?
