@Hayes @AutoCraft Aus does autocraft make a shorter progressive coil than the 75mm you used?
I saw those, but was under the impression you were running slightly different 100-specific coils.Yes, at least according to the Redline Cruisers site. They are the US dealers.
Red Line Slinky Long Travel 80 Series 50mm Rear Intermediate Coil Springs - Red Line Land Cruisers
Slinkys: very interested in these. Reminds me of the parabolic springs for the 60's, but with better vendor support
Question: can one run airbags with the slinkys?
Well - You sold me on them, ordered the same setup from Drew at Just Differentials. Everything showed up by Friday! Will now need to go back thru your thread and get pointers on the install. Sweet!Compression damping is adjustable on the stage 3's. 1 through 10 settings, soft to firm. Factory default equivalent to their non adjustables is 4. For daily driving I've settled on 5 up front and 4 in the rear. That's how I left it for this last Moab trip. It worked great. I imagine that running a heavier load (say full expo setup), one could benefit from running a higher setting. Also, if you were really getting after the high speed whoops you'd want to turn it up.
I'm interested in an update on the Icon stage III shocks. Any issues, likes, dislikes?
Yes, it's true you may get minor pitting. But if one flying a****** rock scores the shaft, you're loosing oil. Happened to me on the freeway (!) with Fox 2.0's. So which is worse? Icon does make a nice SS cover that solves both problems if your not on a budget.Re shock boot: I have heard (back in the day) that boots are not beneficial due to the fact that they do not let water drain away, thus increasing corrosion possibility.
After rebuilding all 4 x 2.5's after 60k, I found the first one takes a while (alright half-a day) and by the third it's an hour a shock. That included a full rebuild with lower mount spherical bearings (PITA). Tools required are a nitrogen pres gauge (Fox is easiest to use) , nitrogen bottle with hose & reg, spanner and homemade 1/4" t-handle for remote resi. I think tools were around $500 not including a vice. To drain, replace the shaft seal and assemble would take about an hour with the rebuild kit and shock oil on hand. Highly recommend having the tools because I don't know how anyone pulls and reinstalls one of these shocks without bleeding nitrogen. Always paying someone to change oil or replace a seal can get expensive fast. Or, at least here it's $200 a shock minimum.
