I think after reading this Ill keep driving my 40,60, and 62s. MIke
I would get a proper diagnoses![]()
I'd buy an 80.
I told him to R&R the stuff...no new axles. I'll prepare for the next time and will watch for chromoly's to come out. Why put in $1050 axles that I can bend again...like Spressoman. He and I are gettin' shafted!
How different are the 100 axles from the 80? I thought they were very similar and could even use some of the same parts
Cruiserdrew said:It sounds like Shotz' axle is bent at the flange from a pinch. Not too surprising considering the amount of ornamental rock crawling it's been subjected to.![]()
They are completely different, might possibly share the same pinion flange, but that's all I can think of.
The shafts themselves are larger in diameter, 32 splines at the diff instead of 30.
They are semifloaters, with a really goofy axle oil seal arrangement, and a sealed bearing that requires a press to service it at all. Not really a friendly axle to deal with in my opinion, at least not in the driveway.
Regarding the housing, Toyota axle housings can and do get bent. It can be pretty subtle. Maybe the 100 is magic in this regard, but all the others get bent axle housings, and bent shafts.
Why not buy a complete axle at a wrecking yard? If you look for one in a front end collision, the rear axle should still be great. Then it's just a matter of swapping in your geared 3rd, change the oil seals and install as a complete unit. As a side benefit, you get a whole bunch of spares.
