Holy Crap! Am I the first and only so far?
So at 105K miles my rear axle seals were leaking. $750 later they R&R'd those along with one new rear bearing that oil was leaking through as well.
Now at 160K the rear seals were leaking again. So today I get the call from my long time buddy at Toyota. He got involved when he seen my truck in there again for the same seal work. Before just R&R'ing the seals and this time BOTH bearings...he wanted to check for something else...axle runout.
Spec is .002 on the rear. My one axle was .005 and the other .009...in other words BENT. He's seen a problem with Tacoma and 4Runner axles thought NOT Land Cruisers. LUCKY ME! And of course he says it's more than likely from 4-wheeling...hitting the sidewalls is what hurts.
So...$1400 for axles. I know I can get them for less. He says if I DON'T put them in now then the seals and bearings will leak once again and probably even sooner. AND, if I have them put it together now and add in axles LATER, then I ruin the new bearings that get pressed onto the current axles.
DOES THIS SOUND HUNKY DOREY?
WOULD YOU REPLACE THE AXLES NOW...JUST IN CASE HE's 100% CORRECT?
HMMM...DOES SLEE HAVE UPGRADED ONES...I'LL HAVE TO LOOK....POO POO!
