I had Redline Motorsports in Fort Collins Dyno the truck last night because the A/F gauge has been acting up, ie: pegs out lean, well it was really surprising to see what the hp and torque was at, 130hp at 2800rpm and 230 ft/lb of torque at 2800rpm, this is on 37" tires and 5:29 gears witha turbo charged 3FE, they said the truck is running perfectly as far as A/F ratio goes but i have a weird drop/spike in horse power and torque right after it hits max at 2800rpm, they were completely stumped on the drop/spike, also i took the truck in to get emmissions done before the dyno and it didn't pass due to running to rich, so i think the cat has to be toasted, i'm going to try and regap the plugs to 35 and clean out the air filter REALLY well and try it again, if that doesn't work i'll try a new cat, also they told me that the A/F gauges that run off of your O2 sensors are pretty much worthless as far as being reliable, so they showed me what they use in their Supra build ups, a 5-Wire wide band gauge, i guess they will tell you exactly what you are running at A/F wise, but at $500 i want to get some more opinions, but for peice of mind that my truck isn't going to blow up from running lean it may be worth it, Brad.
