I think this shows his current mind setSorry for hijack
Hmmm... That doesn't help me. I have a 15 mo old and wheel in the PNW (i.e. rain)...
Hmmm... That doesn't help me. I have a 15 mo old and wheel in the PNW (i.e. rain)...I guess I will have to see where this LX leads!
we based our link setup off this but minus a link
*NEW* 4-Link Long Arm Upgrade - NAXJA Forums -::- North American XJ Association
we got the idea for the axle side mounts from ruff stuff fabrication. do to minimal room.
Just have some warm apple pie, you won't care after that.![]()
got your wheels turning, I see!![]()
i got my ram assist today! i'm using a 1.5x6 inch ram i'm putting in the gears and the aussie this weekend
ive posted build threads before on naxja.org because the black cherokee in the pic is mine![]()
This is actually a large part of the context of my posts. The Cherokee is something of the inverse of the 80 - it gets it stability from a rear leaf spring suspension with a fairly unrestricted front end whereas the 80 is the opposite.
This is why XJ's are so easily to lift to 6"-7" whereas the quad coil Jeeps are not without introducing a lot of undesirable suspension characteristics. The Jeep aftermarket has spent years trying to perfect a long arm conversions and while I don't spend any time around Jeep mods any more my eyes tell me that most quad coil Jeeps are staying at 4" or so of lift for a very good reason, where XJ's are consistently seen at much taller lifts.
This all makes perfect sense on an XJ, because if you go to more of a mid-arm length you will retain the factory suspension design while improving link angles and overall geometry. In other words, a 3-link on an XJ can be designed within the factory geometry front to rear, and can improve strength, clearance, durability, and performance without any material impact to factory designed suspension characteristics. You can easily 3-link any Jeep, because the suspension was designed as a 4-link and the second upper link is always functionally redundant.
If you do a search on my name and "leaf spring", you will note that I have mused from time to time that an 80 could benefit tremendously from a rear leaf conversion while then freeing up the front via 3-link.
I say this because wagons, particularly as they gain weight and lift, generally need a suspension that is designed for stability on one end, and as many an XJ owner has learned, it is usually best to maximize the rear leaf suspension rather than try to replace it. I personally know people who rolled their XJ's on the street after rear coil conversions, and I know people who run the Hammers in 3-linked XJ's with a simple factory designed leaf spring suspension. (I was a founding member of NAXJA, and I see a lot of familiarity in 80's as to the emergence of XJ's - on XJ's it used to be said you couldn't lift more than 3" or run more than 32" tires, but you will find the 80 is harder to get out of the box than the XJ, but the box is much, much bigger. Spend some more time with it and see if you truly disagree.)
What you have done with the 3-link, no matter how you designed it, is more similar in principle to converting the rear leafs on an XJ than it is to 3-linking an XJ. I hope you keep the rig, keep it rubber side down, and spend a couple of years with it. I'd like to see you guys try a rear leaf conversion if you ultimately find the rig to be less stable than you want.
There is more to be done with these rigs, but I don't think it stops with the front suspension. That is just a little hunch of mine, though, and I don't want to guinea pig![]()
SOOOOOO not true. cherokees are always the smallest of the group with the occasional large ones. wranlger tjs are always seen on 35s or larger. Grand cherokees are also hitting the larger suspension scene. A wrangler tjs stability is far worse then an 80 do to its tiny wheel base. I understand what your saying but people do the same link set ups on grand cherokee which is the same basic design but smaller.
