I am looking for a 12 volt to 12 volt Battery tender.
USA
Most tenders are 110 volts to 12 volt.
I have a solar panel which keeps my separated Aux Lithium battery that I use for a fridge charged.
I would like this Lithium battery to act as a battery minder for my main starting battery when the vehicle is left for long periods of time without running it.
That is connect the 12 volt power to a minder which is then connected to my main.
I don't want any back feed, i.e. the main feeding the aux.
What is the best way to hook this up?
Should I look at a low amp dc to dc charger instead?
I don't have an answer for you and I know nothing about the Lithium Battery that you are using, but keep in mind that you need more than 12v to charge a 12v battery. Generally something like 14v +/- a bit. Without a voltage difference you won't charge the battery.
why not just get another charge controller for the battery like you're doing with the Lithium. Use the solar to charge both
Or maybe a charge controller that can do both
A few weeks isn't a long time to sit either, a good battery should have no problem with that. I routinely go months without starting some of my vehicles
^^^ It is true that you (usually) need more than 12V to charge a "12V" battery. But that's at the battery posts. Not at the power source. DC-DC converters can certainly generate 14V from less than 12V.
^ Whereas it may be fine to use 2 charge controllers to the same battery off one panel (if they are set up properly), it is more problematic to use 2 MPPT charge controllers with separate batteries, as their respective algorithms for MPPTracking may not be compatible and things may go wonky somewhere. That would depend on their respective specs. (But I would think that having one of them be PWM -shudder- instead might help with that.)
OP, as to ways to do what you are trying to do, there are many. Inverters, charge controllers of various kinds, converters, isolators, a second panel, etc. But the "best" way would be a function of what you already have equipmentwise, your sensitivity to the cost of anything new, and losses / efficiency you can live with. IOW, it's a very wide question with no obvious answer.
One complication to keep in mind is that you likely want some sort of smart control of the main battery voltage, with floating capability etc. In addition to the fact that you are using 2 different chemistries in your 2 batteries if your starting battery is lead acid. So some smart device would need to be involved.
Having said all that, if I had to take a guess at the cheapest / easiest way to go, I would assume that you already have a 110V smart charger, and just using a cheap inverter (can be very small but should be decent quality, preferably pure sine) would work just fine then, well at least if you have enough solar power to overcome the losses (I'm guessing a continuous 5W or so for the inverter for the sort of power needed). You could be set for well under $50 if you don't already have an inverter. Is it elegant? No. Would I do that? Yes if in a pinch, no otherwise cuz I think I could do better and I'm a nerd for stuff like that. A cheap alternative to the above might be that one PWM controller off the solar panel directly to the main battery but they are not very efficient, so meh. Or, yes, something like that Tekonsha but you'd want to look carefully at the specs, especially regarding the feedback issue. Me, I'd go with something like a Victron Orion DC-DC charger but that's significantly more moolah.
Now, as to whether it'd be better to have the panel connected to the starting battery instead, that's another whole can o' worms.
OP, on a side note, rereading post #3, if you meant that you are leaving the charge controller set to 14.6V all the time, even when the battery is fully charged, that may not be a great idea. My understanding is that LiFeP batteries don't like that.
I am going to test out this one on a couple batteries I have in my garage first.
It's like $10 vs the higher price for a dc to dc. and I do not need high amps to maintain the battery.
I saw some feed back that the Tekonsha will over charge the battery, so I returned it.
Hopkins said it will not over charge the battery.
I'll hook the Back wire fused to a Main Battery, and hook the red wire to the aux battery (also fused).
Then common ground.
Run some very small amp light of something off the main so it has a draw.
Hook a battery charger up to the test aux to simulate the solar panel.
Watch it and verify it will not over charge the main.
If that works then I'm going this route. Several others have used it for same purpose.
Last time I left my LC200 for a couple months and the main battery was so low it would not start it.
My aux 138ah Lithium the dc to dc charges it from the main if turned on, and or solar 100 watt panel.
The Dc to dc does do a final charge to 14.x volts. Usually when I look at it the voltage is 13.x.
Some things run off it 24/7.
So long as you don't have a smart alternator a simple dual sense Voltage Sensing Relay or Automatic Charge Relay will connect the batteries together when the solar is has charged the house battery to some specific voltage threshold. When the solar stops charging it will disconnect them.
The fly in ointment is the lithium battery's charge profile in the solar charge controller won't match what ever the starting battery(ies) want. Unless they're Lithium as well. :) It may be close enough and it may not.
If you're determined to have good charge profile matches to both batteries, then a DC-DC converter with 18VDC-20VDC output driving a the second 'solar' charge controller would be my choice. There a single sense VSR or ACR could be used to only turn on the converter when the house battery(ies) are in Float.
