HZJ75 (1 Viewer)
What rim do you want to ask?:hhmm: Should be at KK.:D
I wish to ask for alloy rim, not 105 steel rim or sunraysia. I need to know the exact place in kk and contact number if available. thanks ;)
That's why i need ur friend help for contact =D
it wrote PCD139.7 X 6 not PCD150X5, it's the same design as urs!
Is a 5 stub rim for 100 series. :mad:
Writing mistake by the seller, title stated as "Ninja King":D
Why not give a buzz to the seller?
What is your budget?:confused: Will try to ask my friend to help you.
Thanks! below RM4800 for 4
Fast and Furious red HZJ75 + turbo
ARB bullbar with side railing + Safari snorkel.;)
1HZ + turbo intercooler.:p
Do you know who is the owner? I had seen it a few times near Apas Mile 3 Industrial area.
hot looking little unit.
About waiting on 4 studs to come in the mail for my turbo and exhaust install!!!
Is that waste gate plumbed back into the exhaust Wong or just out to the open screamer pipe style
Yup! know the owner.:D
What is the 4 studs for? :hhmm:
Waiting to see your mod;)
Yes! Exactly. And down to the end is an air horn tube and is super extra loud screamer. :clap:
Does he use back the original fuel pump? If he place the intercooler in front, where does the aircond goes? :eek:
That bar work is really really good!
Lol..just realised ARB!!
Fuel pump with added compensator, looks similar to 1HDT.
ARB bar work is really good, so as the PRICE!:D
4 studs and nuts are for the turbine flange to connect to the dump pipe.
I just can't be that patient waiting for the 4 studs and nuts to connect.:o Why do you need to send from somewhere??:confused::hhmm:
Where is the air-cond radiator since the intercooler replaced its place?
Patience is a virtue....:D
You have drop in 2 cents into my pocket!
Doing all the mod to my cruiser really test my patience and endurance.
And I conquered.:cheers:
Both the intercooler and condenser can be mounted in front of the radiator.
The aftermarket air-con condenser isn't thick enough that no where to place itself.;)
