crushers said:with a 13BT there is very little extra hp you can squeeze out.
I can't wait till Peter reads this
denis said:I can't wait till Peter reads this![]()
Crushers said:with a 13BT there is very little extra hp you can squeeze out.
crushers said:yep, all those 80 series you see at Moab and other off road trails must be running an D60...
and that video floating around of Roll'n Nolen in Auzzi must have a good shot of his D60 front end somewhere in it...nope he still was running the same 80 series front end...
agreed the smaller front end is weaker than the older full size front end...
hummm, it seems Jeff busted the front and the rear diffs that run. if i remember correctly that the rear busted first and he tried to pull a 7500 lb truck on 35" up a rock slab on just the front diff...Behemoth60 said:I figured you'ld more vehemently agree with me as the caretaker of your HJZ75 spend all of Moab 2002 replacing a broken front carrier, which he managed to break on one of the easiest trails.... without a locker. Then there was the diff that grenanded at Pismo in 2002 on LOOSE SAND!!!! I've hardly spent any time on the serious trails with small diff vehicles, and I already have a great collection of carnage stories.
No sir, you won't convince me of their sutability at all. Especially since it was YOUR TRUCK that first introduced me to their weakness!!!!
Now, I really should go to bed.
Peter STraub
Behemoth60 said:...
Then there was the diff that grenaded at Pismo in 2002 on LOOSE SAND!!!!
crushers said:i think that a full size diff might have broke as well..
drexx said:Ahem! I resemble that remark!
drexx said:And it wasn't exactly loose sand.
Behemoth60 said:As for the whole teeny front diff after 01/90, there's little question about it. The small front diff is *NOT* adequate for anyone serious about wheeling (and by serious about wheeling, I mean someone who knows why good lumbar support is important and has at least heard of Michelin off-road tires)...
rick_d said:peter wrote:
>2. No sleaves for the pistons.
I know, geesh, even Alfa Romeo's have sleeved blocks. 12H-T's are not, idea's on cummins etc?
crushers said:actually Greg and Sheldon are the gurus when it comes to the HDT and the 1HZ, i just play with those engines...
lowenbrau said:The Aussies have proved that you can sleeve anything. They have been doing 2Hs forever and even do 350 Chevy's because I guess they are desirable there. Sleaved/non-sleaved = no concern
