I'm in the process of rebuilding a couple of smog pumps and decided to get a press. If I'm going to buy a press, then I want one that will support rebuilding my stock tranny and transfer case. To those of you with experience rebuild theses items is this unit from Harbor freight going to meet my needs?
BENCHTOP 10 TON HYDRAULIC SHOP PRESS
Includes Hydraulic Pump
Easily remove and install pulleys, U-joints, bearings, gears, and bushings. Spring return ram speeds up your work. Includes two arbor press plates and 60" long pump air hose.
High strength steel construction
Ram to base distance: 19''
Ram to post distance: 7''
Ram travel: 6''
Shipping weight: 144.41 lbs.
Ram travel: 6''
