HVAC fan for RHD
Earth
My 100 series rhd truck has a weak fan.
USDM fans are smaller base and a smaller fan shroud.
After some research I found that the Prius fan from 2001 - 2009 may fit. Both have 8”
Bases and look the same.
Plan is to use the cage from original fan to replace the LHD fan cage and then reverse the wires to have the dc motor run in reverse.🔄
This “should” be a straight forward swap that will be price saving for all the imprint 100series. As an OEM fan is $300+ and new aftermarket is $30-ish
I’m all about OEM parts but this a logical swap for more domestically accessible part.
Order it from partsOUQ.com.
It’s $485 before shipping and any duties.
I’m seeing if I can do it for a bit cheaper for myself and others in the community.
the days of partsouq are done for now... I have 2x duty tax invoices on my desk. one for 40$ and one for $400.
What was the original invoice price? I paid tax for $1500 worth of goods.
Can at least still use the site to get what the part number you need is.
I know the part number and sites, I was just seeing if I can do it more economical by using usdm Toyota fan. $300 + vs under $100
Toyota P/N: 87103-60230
So after trying several fans and combinations, its seems that there is no USDM fan that fits in RHD 100 series. the fan bases are all slightly smaller.
