Wheels for 100 series
New England
Hello, I’m looking at getting a new set of wheels. Just got new tires so looking at sticking with 16 inch. Plus I don’t want to lift it more right now and possibly deal with rubbing. I don’t love the look of the stocks right now as they are worn. I’m looking at KMC impacts as they are a sure fit to OEM specs. Any other suggestions?
The only reason I don’t want to is because of the new tires. Love the tires I have. I don’t mind 16. I prefer smaller rims with bigger tires.
I guess this depends on how long you plan to keep it. If you're like some of us and there is no end in sight, 16's are going to be more and more limiting with tire choices. But worse, it's also very limiting on wheel choices.
My advice would be sell the 16R tires and move to 17s.
Then, I'd say I really love my new Icon Recon Pro 17's, perfect fit, offset looks great, tons of tire choices. The Icon Recon (non pro) is also great, I would have gone with them but they were backordered.
I just did change to new tires and 0 offset 🤦🏻‍♂️😩 Just for whatever it is NO on K03 if you are not lucky balancing would be a problem (ask me why I know)🤦🏻‍♂️ if you can get +25 or +10 offset. Im on 16” 0 offset 285/75/16 dis cut and hammered inside well and still need to do some more due to rubbing on some deep bumps. Im on 2.5inches lift.
17’s are definitely where it’s at.
Whichever wheel you choose, make sure it fits the 100 specifically. Not all 5x150 are the same.
Assuming you’re on 285/75’s(?)- If you go past ≈+25 offset you’ll probly be giving yourself more work to do.
If I do go 17. I want the rock warrior wheels.
Good to know. I’ll keep that in mind.
I’ll check those out. I’ll run these tires until they are gone. Don’t feel like going through the hassle of doing all of that and spending more.
