alia176
I have nothing new to contribute except, is THAT your ugly mug in the pic?
You sure the kid is yours?
You sure the kid is yours? Follow along with the video below to see how to install our site as a web app on your home screen.
You sure the kid is yours? I have had mine stall on steep inclines when I forget to lock the CDL. I was able to stop immediately and there was no harm, I just started it back up and locked the CDL and up the hill I went.
My 80 and it sounds like yours do not like loosing traction on inclines with the CDL unlocked, mine doesn't stall everytime, but it has happened a few times. I have never had a problem with the CDL locked, so if you are going to be climbing anything I would recommmend locking the CDL.
Jack
And B it should not then have thrown everything into "neutral" allowing me to go barelling backwards down the trail.
First time I stood on the brakes and nothing. Second time it seemed like I was going even faster and I was pumping like a mad man. Nothing at all. It was the brush that stopped me.
Don't do hill climbs with CDL off. It will act as an open diff. If you loose traction or unload the front, then nothing is going to keep the back axle from holding you in place. Did you try the hill with CDL locked?
Why truck stalled, I do not know.
Jack
Here is the 1st clue. Jack's is a '96, yours is a '97. Could it be something with the OBII setup? Both of you were CDL unlocked. Christo has excellent point while climbing. Viewing hill and pucker factor & the coward that I am, I know I would have had CDL locked - that's NOT just Monday Morning Quarterbacking talking, either. NLXTACY, you need to go back to that hill and try it again with CDL locked, AFTER you install your sliders, eh!
I'm guessing that since you had the CDL unlocked, your wheels started spinning, you backed off the skinny pedal to try and get traction back, the 80 started rolling backwards, the engine stalled out, auto has no pressure, brakes have no power boost and you're off on toads wild ride...
cheers,
george.
Don't you have an e-brake?
There have been a couple of reports where a new fuel filter resolved problems with stalling on steep inclines. Junk was one of those reports a few years ago. The brake booster should have enough stored vacuum to stop the vehicle when the engine stalls. A few weeks ago, a friend with a '94 stalled at the top of a steep obstacle. We were playing in the rocks so not quite the same as your flat trail but his brakes held just fine even with the engine not running.
Peddle pressure increases dramatically without vacuum boost but I still think you should be able to stop the truck. I could be wrong.
-B-
Are you sure you were rolling and not sliding? Could you have locked your brakes and slid down the hill?
Tires lost traction for ONE second at the very top then the truck literally rolled. 100% rolled and didn't slide down. When I say I tried to use the brakes, I TRIED. I had all 200# of me standing on the brakes which did nothing and then tried pumping like a mad man and zero. I had my kid and dog in the truck and all I kept telling myself is NOT to roll the truck so thats why I was focusing on staying straight and trying to bend the brake pedal. If I was sliding it would have been a slower decent. I was in free fall and GAINING speed.
It was seriously freaky and especially the second time scared the SH!T out of me.
I imagine it was very scary, especially with the kid in the car.
I think it's really bizarre that you had NO brakes, even without power assist. I've lost power before, but when you really stand on the brakes, they bite. Do you have any other problems with your brakes?
There is something amiss with your braking system and I would not put myself or my family in that position again until it was resolved. On most systems, there is a check valve in the power brake booster. I don't have the FSM handy but check yours to see how this works on the Toyota system.
"Vacuum boosters also have an external one-way check valve at the hose inlet that closes when the engine is either shut off or stalls. This traps vacuum inside the booster so it can still provide one or two power assisted stops until the engine is restarted. The valve also helps maintain vacuum when intake vacuum is low (when the engine is under load or is running at wide open throttle). You can check the valve by removing it and trying to blow through it from both sides. It should pass air from the rear but not from the front."
-B-
your braking issue sounds like a vacuum/pressure loss (not to be obvious). Engine off braking performance should remain same for at least 10 vehicle stops - there should be enough vacuum in the system to assist braking.
is it possible for you to replicate the failure on level surface with engine off? if your cap/lid wasn't tight, or if the seal around it somehow failed, all vacuum would be lost.
would be good if you could replicate the failure and go from there.
