This is the parts location diagram for the BL pucks.
#1: Top of the bolts offer easy access from the engine bay.
#2: DS: Need to pull the left foot pad, door sill plate and just pry the carpet & pad up enough to get your hand to this BL bolt location. All interior bolt recesses are covered by a rubber/plastic plug that is easily pryed loose with a small screwdriver to allow the BL bolt to be removed.
#3: This one resides under the rear outer portion of the front seats. You need to remove the rear seat bracket bolts to allow the seat to be tilted up to allow access to these BL bolt locations. These are accessed by removing the second row door sill plates and raising the carpet & pad enough to stretch your hand to these locations.
#4: These are accessed from the second row seat area. You need to remove the plastic "step" that is intended for entry/exit from 3rd row seat area. Then as before gently pry the carpet and pad to locate the black oval BL plug; remove plug to allow BL bolt to be removed.
#5: This one is the most difficult...especially if you have installed rear drawers as they must be removed to allow access to the inner fender panel. Remove the plastic trim that bridges the tail gate and the body then the plastic retainers that hold the inner panels (this is where the factory jack is/was located...and same for the PS side sans jack
). This one requires a mirror and magnet to view and access properly.
#6: This is also a little complicated. You'll need to fab a metal holder for the puck then either tack weld or screw into the cross member to bridge the gap at this puck location as this puck can not be removed (or at least I couldn't figure out how to remove it!).
This is a cheap and necessary mod for those running 35" off-road if you want to maximize suspension up travel without rubbing. Note: I am running 1" front spacers: This is the reason I was rubbing the fender! I have not been able to measure the fan blade to shroud clearance...but with the 12mm lift rubbing has not been a problem post lift.
My OEM bolts were corroded...especially the #5 location. You'll need to special order the appropriate BL bolts. Note: I used the factory #2 in the #3 location; and I used the factory #3 in the #4 location. If anyone figures out a way to remove #6 please let me know
Thanks again Darren and Lee!!!
