Final result picturessss??!!
I'm getting ready to do a 25 or 30mm body lift to clear my 36x12.5 Simex ET II's and did a partial dry run a couple of days ago looking for issues and measuring the bolts. The lengths in the diagram are the thread length from the washer on the OEM bolts. If you use none OEM bolts you'd need to add 5mm to the lengths in the diagram to allow for the washer thickness assuming you press the OEM washers off and re-use them or use a similar washer. All of the OEM bolts had about 12mm of 'spare' thread showing when done up on mine. All of the OEM bolts have none threaded sections at the end, some more than others, so the actual bolt lengths are much longer but that shouldn't matter for working out what bolts you need. For my lift I'll use No. 2 OEM bolts in the 3,4 and 5 positions and none OEM 170mm long in the 1 & 2 positions. Hope this helps the achiveOn your pic, did you list the OEM lengths of the bolts or the replacements?
A picture of the bolts location would be great.
Is there a way to check for the bolts from the outside? I'd like to avoid pulling up the carpet, etc. If not, how far in from the outside of the body are the bolts? About the same as the others? Closer in the middle?
You mentioned:"I'm getting ready to do a 25 or 30mm body lift to clear my 36x12.5 Simex ET II's".
It seems you did a 16 mm BL. Any reasons why not a little higher? Were you able to fit bigger tires than 35"?
Here's a photo of one of the offending bolts. This is from the rear of the truck looking forwards, on the UK DS, just by the axle end of the upper control arm. Circled in red you can see the chassis cross member with a bracket on it with a captive nut and from that there's a stud going up into a hole in the body. In this picture the big washer and nut are missing to show the hole more clearly, otherwise you'd just see the underside of the washer.
I've lowered the radiator fan shroud about 8mm now as well and have much better fan clearance.
Guess that means I'm not special after all thenJon, Thanks for the photo and yes I have your offending bolts also. I say your offending bolts because without a body lift they are not offending.![]()
I can have a go but I didn't take picturesCan you post up on how you lowered your shroud?
The main thing I did was trim the tabs on the bottom of the shroud and the holders they fit into on the bottom of the radiator about 5mm each. I also removed the little rubber covers from those tabs at the bottom of the shroud and cut the ends off before refitting them. That dropped my shroud and then I slotted the tabs on the top of the shroud that bolt up to the radiator so they would still fit just about. There's one bolt half way down the side of the shroud that I had to leave out and one of the expansion bottle holes got a zip tie through it to hold it in place. Sounds a bit shaky but it's all very firm or I would have just removed the shroud completely (not going to be a problem with UK weather!).
