How's your 100 Series Body Lift? (1 Viewer)
How come I do not see big gap between bumper and body?
There's a big gap at the rear. Front does not have that issue as it no longer attaches to the frame anywhere, only the body.
The bumper originally attached to the frame and body. I've trimmed so much off that the frame mounts are no longer in play. Still stable though after plating it to support the lights
Just installed The TT 1" kit yesterday. Fairly happy with the results. Bolt length varied quite a bit and had a couple that had just enough thread to allow the locking nut to travel just past the tip of the bolt. Since I had rust free hardware I was able to retain the oem locknuts which I much prefer over the non-locking nuts sent with the kit. No instructions were sent with the kit but fortunately common sense and some tips from the forum allow for a smooth install. Everything tightened down well and threw a torque wrench on just to check where I pulled too, around 45 ftlbs. Only additional step I wish I had taken was to tack the oem locking plates to the new bolts so I can service/check on them without pulling the interior. Didn't dawn on me until I was well into the assembly phase.
* Some input needed from others that have installed these kits. I did have a bit of trouble with the #1 front pucks/body mounts, especially the left.
It torques down but I am getting some deflection in the lower oem mount and now it is sitting a bit askew. I have removed to inspect and it is sitting square until I get the bolts cinched down. It doesn't have a "positive" stop when tightening down either. The right front mount is also a bit cocked but took the torque much better, like the rest of the bolts behind it.
Going back into the shop today to wrap up wheels/tires and alignment so I'll take a pic of the mount if i can't solve.
**EDIT: I discovered that my problem with the #1 mount is that the mount bush/sleeve is bent causing the lower rubber mount to sit askew and prematurely seat against the bottom side of the frame post. Doesn't appear to be causing any issues for now but fortunately it's an easy one to get to so I can swap out the bush later down the road.
Nope, still plenty of slack.
Only issue I have encountered, is some rattling from the rear end…..but that was because I didn’t re-attach the parking brake guide loops. Fixed that.
Did you just trim off the bottom of the rear bumper so it doesn't attach to the frame any longer?
Overall, I am happy that I did the body lift. The lift itself is a quick job. I was in under 2 hours by the time I was lifting the body off the frame.
It's the OCD detail work that takes up a lot of time and turns a 3-4 hour job into a full weekend, but worth the results.
I had a little surface corrosion between the body and mounts so I addressed that before installing the BL pucks. Of course, followed up by cleaning this and that. Fab'ing the upper rad brackets, trimming and fitting the front and rear bumpers to fit properly take a bit of time. followed it all up with a pinch weld beatdown, painting, and sealing the areas for a clean finish.
I capped off my BL with a fresh set of Pizza cutter 35"s on 17x8 30et FN LC100 edition 5 stars, and an alignment.
Ok. I wanted to share my experience.
I bought the kit from Duiser with my fingers crossed.
Everything went excellent.
Shipped the same day and got it in my door in 3 days. I was amazed.
Instructions included. Hardware was good.
I would probably include washers also.
Installation took around 2 1/2 hours to me and my brother.
I did the radiator mounts while he was taking the trim out inside. Pretty smooth.
Make sure you have some spare trim clips just in case for your inner trim panels.
Trucks looks great and handles great also.
Only thing is that you have to make sure the stick is in P all the way in so you can remove key. No big deal. Already used to it.
Big advice. Change your heater T’s before doing this job. Mine snapped doing the test drive. Good luck i already bought them but didn’t replace before. Now i have new T’s also with the job.
The following pictures show the final results.
See the gap on the bumpers, i think nobody have posted a good picture showing on how much they stretch.
I run 295/75/18’s, Reindex front OEM TB’s, 1.25 wheel spacers and 2860 OME springs plus the 1” body lift all the way around.
Thank you for the help and advice guys!!
View attachment 1675335 View attachment 1675336 View attachment 1675337 View attachment 1675338 View attachment 1675339
This looks insanely good. Super clean. Might be running something similar soon.
you bet. the plastics sit right against the crossmember, so really solid. And, since I made the spacer to stack on top, the bumper still operates as oem, no flimsyness/stretching/don't step wackyness
  • Like
Reactions: GTV
In case it helps, to help with my steering column I purchased a second "yoke" from Toyota and welded it into a longer sliding extension. I purchased very expensive aftermarket steering extension from New Zealand and it was awful.
Part number from Toyota was 45219-60080.
View attachment 3433542View attachment 3433543
I went slightly different route, but nearly the same plan.
The available steering extensions work, but have some caveats, modifications required, or actually do not work at all.
Flat out offroad - offers ‘105/100 steering extension’ incorrect, it only work on 100 with telescopic steering, firewall modification, placement at upper end of engine steering link. And, requires re-clocking of lower link to rack spline 45°. Fits 105 at lower link / rack, requires re-clocking 45°. Does not fit 100 with non telescopic steering.
Nice work! Hope this works out well for you
