In the area outlined the finish looks a little "off"; but the surface isn't scored or flaking. Doesn't look like anything got dragged through the journal.
Follow the FSM for inspections. If it all checks out, reassemble the beastie.
I don't know how experienced you are, so if this advise is unwarranted just tell me you've got this:
Don't forget to use an assembly lube on the journals and cams before putting the cam shaft in the bearings.
After assembly and before the first start-up, keep the spark plugs out and crank the engine over until you see oil flowing in the head while looking in the valve cover.
This ensures the journals are lubricated and ready to go before starting.
