Ugly Dwarf
I was doing some work on my new cruiser yesterday afternoon, and I wanted to take a closer look at the driver side master window switch that had been acting up since I picked up the truck last weekend.
That siad, I of course ASSuMEd I needed to take the door panel off to get at the switch. I'll note this is not true, and you can get to the window / lock switches without removing anything else. After popping out the plastic screw / pin thing-a-ma-bobs that go around the outside edge of the door, I could tell it was still hanging up on some sort of securing devices in the middle.
It was not obvious to me where these might be located or how to get at them, so I started searching here. I found a few people who had written suggestions on where to look and some pictures of removing the 100 series pannels, and was able to figure it out from there, but I thought I'd post up the 80 series pix in case someone else needed them.
If you need to get at the window / lock switches, you can just pry up on the front of it, then lift it out. You'll need to disconnect a plug at the back of it to remove it completely.
To remove the door pannel, you'll need to go through additional steps as well.
Remove the arm rest.
I only seem to be able to attach three pix per post, so I'll continue this in a minute
