How to professionally refinish your OEM rims for $20
Super77
Seattle
I’m a fan of the OE rims. The 16” ones on the early 100s in particular are functional and so cheap they’re practically disposable, but they don’t need to look that way. I scored some on FBM for next to nothing, but they were covered in Plasti-Dip. I’ll share how I made them look nearly factory-new.
First, tackling the Plasti-Dip. It’s best done with a pressure washer, working from the outside in. If it was laid on thick and you’re lucky, it will come off in almost one piece. Otherwise, a wire brush and some acetone are your friends.
I had the tires and wheel weights removed. The rim underneath was in ok shape, with a little curb rash and a few dings that I filled with JB Weld. After the usual scrub, degrease, scuff, and dry, time for an alloy silver topcoat. I chose not to change the color, and Raptor 1K silver was a near dead match to the factory silver paint:
$20 at AutoZone. Spot prime where there is bare metal, and go easy on the topcoat. You want to keep it thin so the cast alloy texture does not get filled. 1 can lasted me for 3 wheels with just a bit left over.
Let the topcoat FULLY dry. 3 days minimum, up to a week if it’s cold or humid. It cannot be off-gassing even a little bit for the next step.
You’ll be clearcoating with this:
About $30 for a can. I cannot say enough good things about this product. I’ve painted in a pro body shop, and results I get in my garage with SprayMax rival it. Anyone who has ever chased that super-glossy wet look with a rattlecan knows it’s impossible. The best you ever get is a semi-gloss that you can scratch with your fingernail. This is a 2-part urethane that gets mixed in the can, cures to a rock hard glassy finish (you can also get it in satin and matte).
It’s worth taking precautions, both for your health and getting a factory finish.
I use a cheap painting tent with an exhaust fan. It eliminates most of the dust and bugs that always seem to land in your wet paint. SprayMax requires good PPE: get a proper respirator (not a face mask), gloves, goggles. Tyvek suit if you’re sensitive. The warnings on the can don’t mess around.
Spraying the clear coat takes a little getting used to. After punching the button on the bottom, which catalyzes the urethane, you have 48 hours to finish the can (I’ve doubled that by storing it in the fridge). Spray a light tack coat, let it flash off, followed by 2 wet finish coats, 15-20 minutes apart. You can lay SprayMax on more heavily than regular rattlecan paint, but it will run if you’re not careful. Let the last coat sit for an hour, then carefully move it to a warm dry place to cure for about a day. Heat up to 120F speeds things up significantly. This is what it looks like after curing:
It’s hard to capture the results with a camera, but I coated over the chrome logo on the caps and it’s so clear that you cannot tell that the chrome has anything on it.
Total spent for refinishing 3 wheels and 1 cap: about $60, plus a day of labor. I like the glossy finish because it sheds brake dust better, but if a more “natural” alloy look is your thing, the satin or matte clearcoat will give you that.
looks great. whats your method to mask the tires?
Many short pieces of blue masking tape, tucked into between the tire and rim. Takes about 15 min. I had 3 wheels, 1 still had a good tire so didn’t remove it.
Did you paint the backside?
I have an extra set of OEM 5spoke 18”s that came on the ‘06 and ‘07’s, and am looking to follow your lead.
Gave the back a good scrub, but no paint.
Nice work, thanks for cluing us in on your methods.
Any input from you guys on fixing a peeling clear coat on roof and hood?
DipYourCar has a new peelable high gloss clearcoat, which is interesting. Problem is it costs $239 / gal, which should do the whole car, or multiple hoods and roofs. I have not tried it - but you could be the pioneer.
Well now I'm really confused. Why would you want a clearcoat that's peelable? Isn't the clearcoat there to protect the underlying paint?
Clearly I'm not a painter of cars...
Alternative to clear film protector?
Because it could cover the problem at low cost without molesting or damaging the substrate. It would most likely be a temporary measure - perhaps 2 or 3 years, or up to 5 years with a second application. This would buy some time to allow you to decide whether the vehicle is worthy of very expensive proper paint job or if it should be allowed to wither away and be parted out at a junk yard. Not every 100 series is worthy of a proper repair of even the hood and the roof. I think it's going to be a successful product though they probably need to get the price and buy quantity down.
If your clearcoat is completely peeled all the way to the base paint, you'll need to sand and paint since the new clear will accentuate any blemishes or discoloration of the base color. Anything else you do won't look good, and if it does it'll be for a very short time.
Repainting is on my short list of things to do on my thundercloud LC, it looks awful from the brutal Florida weather, and I'm still debating on a color change, a LOT more work though..
For rims I used a plastic cards deck, tried paper index cards too but not as easy to slide in. Never tried the dish soap trick, worth a try.
Prep work is the most important part, spraying is 10% of the job.
BTW. Nice job @Super77 , look very close to OEM.
I believe the 06-07 wheels have a different shade paint so I wouldn't repaint unless messed up. You can try and replicate it with the Shadow paint from Duplicolor, I tried it on a different car and it's a pretty nice effect.
Follow-up: if I had to do it over, I’d probably use something closer to a true base coat silver with enough “tooth” to bond to the SprayMax clear. I noticed when I got the wheels back from the tire shop that the clear peeled a little on the lip. It’s fine for a $20/wheel job, and these are just my extra spares. When I do the actual wheels currently on the vehicle, I’ll probably order a couple of cans of custom mixed silver basecoat.
Where would you get such a base coat? I don't want to have to redo my paint job anytime soon.
