any suggestions on removing the fiberglass top to restore hardtop? do I just drill out the rivets?
Thanks
Rob
Thanks
Rob
A quick recommendation. If you haven't already removed the old drip rail from the top, use it to pattern the new sections from CCOT. I put the top upside down, lay the CCOT drip rail in place and tack weld it together. That way, you get exactly the right shape and the holes are all in the right place. If you wait til after you remove the old drip rail, you will be likely fighting the top moving around and may not have a good fit when you reassemble
Don
www.wolfcreekrodworks.com
