They should not break unless over tightned or have sat for very long periods, like years and rusted on. Mike
The first thing I did was buy a tap and a die for that thread size and pitch. They were not easy to find. I had to go to a special tool store that sells machine tools. I ran the die over all the wheel studs that were messed up. The ones that were too far gone got replaced. I think it was 3 of them. The next thing I did was run a tap in all the lug nuts that had gotten messed up by the boogered up studs.
Just a few things that will cause studs to break when you remove them;They should not break unless over tightned or have sat for very long periods, like years and rusted on. Mike
Why didn't you just replace the lugs?
When I bought my '99 2 years ago, it had 5 studs that were screwed up. It was an AZ truck so rust was not an issue. The first thing I did was buy a tap and a die for that thread size and pitch. They were not easy to find. I had to go to a special tool store that sells machine tools. I ran the die over all the wheel studs that were messed up. The ones that were too far gone got replaced. I think it was 3 of them. The next thing I did was run a tap in all the lug nuts that had gotten messed up by the boogered up studs. Lastly, I applied some anti-seize to every stud on the truck prior to putting all the lug nuts back on. I think the problem probably was caused by 2 factors: Overtorqueing and not using any thread lubricant. It resulted in stripped and galled threads.
If you have seized lug nuts they come off real easy with a 1/2" breaker bar and a 30" cheater pipe. Break like glass. Replaced front studs and now doing the rear. Also replaced all the lug nuts for insurance. At over $9.00 each it's a lot of $ because some idiot likes to run his impact wrench at light speed. I wonder how many times the lugs nuts have been removed and replaced? Will have a friendly discussion with the next person rotating my tires. Before they are touched!
Yes, that is the stud/nut thread size and pitch.Stud size 14mm x 1.5, eh?
