ummm ARB won't strengthen the housing itself and that is the weak point of the small front center unit.
the electric HOUSING is stronger than the open one.
whats the difference between the locker and non locker housings for the increased strength?
the webbing design itself.
the open has 2 scrawny chunks of cast holding it together. the elec has a much beafier casting design.
i will see if i can find some pics to compare.
when the open breaks it is usually the casting between the ring gear mounted cast and the pinion casting. those 2 pieces of cast crack under the pressure.
I talked to Bobby longfield about the inner toyota axles for the hzj79
modern 7* series birfs ( from 8" HP reverse ) are the same as in the 80 series . ? thought they are bit smaller ? ( in the bell diameter )
I have heard of guys putting the 80 series hub and knuckle on the 79 series to get the 6 lugnut pattern.
