How much primer and paint did you use on your FJ40 body?
North carolina
I’m in the middle of planning out painting my FJ40 and plan on priming the entire body inside and out (no chassis/axles). I’ll be using Restoration Shop self-etch, epoxy, and high-build primers.
For those of you who’ve actually painted your own FJ40:
How much primer did you end up using?
How much paint did you end up using?
Did a gallon of each type cover the body, or did you need more?
Any tips for avoiding waste (especially inside the tub and under dash)?
Trying to get real-world numbers before I start mixing so I don’t run out or overspend. Appreciate any advice from folks who’ve done it already.
A neighbor did the work on mine. He painted the outside including the roof top and the inside not including the roof; back about 1985. It was Flat Tan auto paint at $50/gal. Price of job included 1 gal. It wasn't even close enough, he bought the second gallon, still not enough so I bought the 3 gallon and ended up with like a pint in a can as left over. He didn't know Flat paint has to be shot as is - no thinning to shoot when he did the bid. Anyway, 7 coats on the outside and 5 on the inside - most of its still sorta there and look good for many years
Having a hard time remembering how much primer but i can say that 532 Mustard over a white sealer needs
almost every ounce of 2 gallons to get every part coated well in a frame off. @dmaddox had same experience.
Sounds like @charliemeyer007 was using a single stage paint in the above post. Mine included the 2 gallons of color
and anywhere from 3 to 5 coats of clear coat on top of it....so bit different process
Even though I had a rotisserie...its nigh impossible to get all the body done well in one spray. I would suggest you
get the underside done first on the body and then in a different spray iteration tackle the topside.
I used the following to just paint the exterior and dash. I painted the rest of the inside and underneath with different products:
  • 1/2 gallon of primer. 2 coats
  • 1.5 gallons of paint. 4-5 coats
  • 1.5 gallons of clear. 4-5 coats
