how much coolant will come out if I pull the thermostat? (2 Viewers)
planets
4 mos ago I did the coolant, should've but didn't do the thermostat. How much coolant will come out if I change the t-stat without draining? :confused:
wd
a fair amount of the block coolant, some of the heaters, half of the rad?
look at the vertical position and the hoses...
sorry no clear number
A whole lot will come out, at least half. Drain the radiator into a clean container and put the same stuff back in after you finish. You will lose some so you will need to top it off.
