Bet that's a comfy ride..... You ought to experiment with lesser tire pressures for overall ride quality improvement, on road. Your kidneys may thank you. Yes, they're E rated and yes the sidewall may claim 55psi, but that's for max load capacities, which you're far from. I don't run but 70psi on an F350 that's usually loaded to the GVWR. Regardless, E rated tires are not going to afford much traction benefits below15psi, since the side walls are stiff. Can you run less? Why, yes....it just doesn't afford much of a traction increase, so why run the risk of sidewall punctures or other potential maladies, however rare they may be? That said, it's still a good practice to air down to minimize tire chunking, especially in the rocks, but don't think that responsible wheeling at 15psi is cause for concern of the bead dislodging. Have ran KM2s (D rated) on OE LX wheels down to 8psi, literally no increase in traction below 15psi, couldn't visually see the tire deflating less than 20psi, and never pulled a tire off.
