hood issues
I would pick something that doesn't work and do a full diagnosis on it, if it is related you will find the fault and fix it all. You will need a wiring diagram, a tester and some electrical knowledge. Pay close attention for water ingress or loose connections at the ECU's in your kick panels. Check all fuses and clean them up with contact cleaner.
