Builds Homer's 2003 GX470 Build 8.2 4.56 2.5 34s (8 Viewers)
IFS will always be better on the "fire roads"/desert running and through the whoops than a solid axle without spending a lot. Rocks and anything that needs a lot of low speed flex, solid axle wins all day
I concur with @captainva…so true.
First of all, it’s easy for Jeeps to upgrade to 35s and 37s. One jeep was on 37s and another on 35s.
On this shakedown run for my mods, there were rocks, ruts, hills with a handful of technical sections, and an 11 mile sandy and washboard trail that I was running between 25 and 45 mph.
Overall the most difficult and technical sections were only rated like a 5 out of 10. But I chose this trail for the variety of terrain.
These Jeeps ate the slow stuff for breakfast. However, the Jeeps complained that in the faster washboard section where we going faster everything was shaking pretty good including the steering wheel.
And I was doing like 80 mph on some sections of interstate 10 where the speed limit is 75 mph. Love how steady and smooth I was driving. The road force balance really fixed my vibrations at highway speed.
And Jeeps spend money too on upgrades…they don’t leave them stock! This one on 37s
Pretty awesome flex for sure! I'll likely add a set of those to the longer-term list, or potentially DIY a set if the bushings and shells are available separately.
One question - how have you been noticing overall Jeep vs. GX performance? My GX has seems quite a bit faster on higher-speed rutted/washboard stuff and highways than my buddy's Jeep. Not sure if it was IFS vs. SFA or just a shock setup thing. He can pretty significantly out-flex me, however.
Not sure if the duroflex joints are sold separately, but that’s an idea
Just remember that these Apache Offroad ones are offset and extended (but not adjustable) and super beefy.
I was trying to hit the rear lower ones on rocks to see if they were like rock sliders but I missed…hit air. Only my engine skid plate, rear differential pumpkin, front driver tire, and muffler made contact with something.
When I get around do them, I'll look at the cost of fabbing them out of DOM tubing vs. just buying them pre-built. Sometimes it's easier to just buy pre-built, sometimes it's cost effective to fab something. Often depends on where they are made - offshore stuff is often cheaper than buying the materials here and building themselves.
I’ve been researching 2” squarish fog lights to complete my front bumper setup.
I came across a good video on these smaller 2” fog lights
I wanted something street legal (SAE) and something to go along with my 4” and 3” squarish Auxbeam combo lights (non sae)
Decided on the Morimoto hxb 1banger 2” sae wide beam pattern. Photo doesn’t include the 2” morimoto 1banger yellow sae fog lights
Also, installed the beefy Goliath recovery points to fully support my Restless front bumper for winching and kinetic rope recoveries
Finished the lights for the bumper
1. Auxbeam 4 Inch LED Driving Light, CUBE-Z Series 112W Cube Spot Flood Combo Beam with Amber Covers
2. Auxbeam 3 Inch 84W LED Pods DRL & Turn Signal 9600LM Spot Flood Combo Ditch Lights XP-Ultra Series with covers
3. Morimoto 1Banger HXB LED Pod (Wide / Yellow / Set) SAE DOT fog light (white lenses and bracket also ordered)
The moritomo 1Bangers are wired to the stock fog light switch on the left of steering wheel.
The four Auxbeam lights are on a single aftermarket switch.
Projects remaining:
1. Install JW Offroad tire swing out by February 2025 — Done
2. Get passenger side long drawers completed by Feb 2025 — Done
3. Install Dobinson C59-701V rear coils by Feb 2025 — Done
4. Do the trifecta in Moab by Fall of 2025 — can’t wait
Added the JW Offroad Swingout Tire Carrier and Overlander Custom Drawers both on the passenger side.
The extra load with my gear cause my Dobinson C59-675Vs with 3/4” Cornfed spacer to sag. So, now on Dobinson C59-701V
Now I’m about 3” lifted in the rear and 2.25” in the front with 3/4 of my camping gear loaded.
Once fully loaded, I’m expecting to be about 1” taller in the rear which could be an invitation for more weight. Ideally, I would like under 1” rake and closer to 1/2” rake.
That's nice to see a swing out that fits with a Gobi ladder!
Neither of the door mounted ones do, and you hardly see other bumper swing outs with a ladder, so thanks for sharing your pic!
How was the install on the tire carrier? Mine is getting shipped this week. I used to be a big proponent of the door-mounted carrier until my door started rattling. Come to find out, some of the spot welds on the inside of the door have popped. This looks like the best economical solution.
First, I bought mine used without instructions. Some things were put together already, so that saved me time.
Also, this is my first tire carrier.
However, JW Offroad has the install instructions on their web site and they are pretty good. I also watched a couple of YouTube videos on installing the swingout tire carrier on a GX460. I say do the same…read the instructions and watch YouTube to get a feel for it.
I had to buy one of those step drill bits for metal to make a hole in the stock metal bumper, I had to buy a big socket for the bolt and nut on the hinge (need 28mm but I could only get a 1 1/8” socket; instructions say 36mm but that’s way too big of a socket) and 1 1/8” = 28.5mm socket worked perfectly for me.
Other than that…I had everything else including tools to cut the plastic bumper and rubber trim to add along the edge of the bumper where I cut.
So, go over the list of tools needed and have them all ready.
It’s just tedious to bolt and align everything, but I’m a 1 banana mechanic and I was able to do it!
If you have any issues, you can always reach out to me.
Josh at JW Offroad is very helpful if you buy it new from him. He tried to help me because I had the main welded/attached bolt on the swingout about 1/2” too short. He was going to send me a fix, but never did. Keep in mind that I bought used, so he didn’t have to talk to me. I figured something out myself that’s kinda half fixed to add the nut to the too short welded bolt. He recognized the issue and said he had a fix.
Good luck with the install. It took me a couple of weekends because of my hesitation to cut the plastic bumper and trying to figure out my issue with the short welded bolt.
My 33” tires looks smallish now…after lifting the rear!
I went out to a nearby trail (75 minutes away) to shakeout my latest mods (rear tire Swingout, 701V coils, fog lights on bumper) and lo and behold…my rear driver side shock top nut fell off!
I had to limp off the trail and drive back home slowly. Luckily, my shock was only bruised and I ordered a new icon nut/bushing kit.
I should have triple checked my nuts at the door!
View attachment 3842079View attachment 3842080View attachment 3842081View attachment 3842082
Always check your nuts.
It’s all good now…Icon bushing kit arrived quickly and nut surgery was performed!
The kit has a standard nut, not a nylock?😱
Ooooo, looks like some Prado tail lights should be in your future, to. reclaim functional reverse lights! 😈🤘
The rig is looking great man, some real big changes recently!!!.👍👍👍
Ooooo, looks like some prad tail lights should be in your future, to.reclaim functional reverse ligjts! 😈🤘
The rig is looking great man, some real.big changes recently!!!.👍👍👍
The ICON rear shocks 56550 come with a standard top nut (not nylon).
The ICON bushing kit also comes with a standard top nut.
I’m going to remove the top nut and add some blue loctite asap
And yes…finally made the IG changes with the front bumper and rear tire swingout
I would suggest getting a nyloc nut. Any hardware store should have one.
Drawers on the passenger side to store all my tools, recovery gear, spare parts, and fluids.
Fridge, Bluetti power station, and box with recovery straps all sit on top of the drawers and sleep with me.
Solo 75x25x4 foam trifold mattress cut to hug the wheel wells. Plywood underneath with adjustable feet to level the wood.
When mattress is folded, I can carry my kitchen Plano box, water jugs, and a long bag for my tarps and shade.
It’s my setup for solo travel and dispersed camping.
Very nice setup. You probably have a foot more headroom than I do with twin drawers.
Yeah…my drawer is 11” tall, so about a foot more. I hope to test out the setup this weekend.
The trifold foam mattress is new, so I’ll test out if 4” is thick enough. All my other Tri fold mattresses were 6” thick…bulky but comfy.
I do have a 3/4” thick and short backpacking air pad that I carry in case I need extra padding in the upper torso area.
