Home Made Tools (1 Viewer)
LAMBCRUSHER
In the lab
I am not finding any threads involving them here- search is not as useful as it used to be...Lets have any and all home made tools pics and threads linked here, please?...I am thinking of turning a bar clamp into a valve spring compressor...has anyone done a wood lathe based valve face grinder?
here's one I just made--a hose release tool-poke the pointy end underneath the hose between it and the hose connection--run it around the connection to break loose the sticky the clamp made--works great!
HANDY, I like it.
Craftsman makes a tool that is perfect for removing hoses... $2.47 each, not worth making your own.
Sears.com
spin_prod_1066498212
Made this so I could lift the axle with a single jack point. It goes without saying that jack stands are required before doing any work, but it works work to lift both tires off the ground and get a set of stands in there
Sent from my iPhone
I agree completely, the axle piece actually has a pretty good saddle on it and there is a bolt that attaches to the jack pad (thru hole). I do want to add some angle to create a saddle for the diff to keep it from sliding. And as mentioned, no crawling under the truck without Jack stands!
Sent from my iPhone
Actuall is a railroad track jack with some material added to it. Many hours behind one of these. Darn tough to break
My homemade F-series crankshaft immobilizer (to take off or torque on the big crankshaft pulley bolt).
Sears.com
Sears is almost 30 miles from me--at 10 MPG, I'd spend $12 or more just to get there-This thing cost me 20 minutes of work time to make--no contest-
Seems like this would be easy to do--you could convert the tool holder to hold the facing burr---someone has to have done this?
Not exactly a tool but I keep a set of studs around to use as guides when I replace the oil pan on a F series engine. I thread 4 of them into the engine then position the pan and hold it with nuts. Then I use a few bolts to pull the pan up, remove the studs and finish installing the bolts.
The first fabricated tool I ever saw was using old head bolts with the heads cut off and a slot cut in the top as guides to get the engine head back on straight.
I like to make three of them, and put them on the last three bolts in the tightening pattern. Then when I install the rest of the bolts, I can remove them with a large slotted screwdriver and install the remaining three bolts, in sequence.
I like to use 2x6 with regular door hinges to build impromptu sheet metal brake of the size required. Also, threaded rod makes excellent clamps.
My dad could out-cobble anyone, though. He once took the front end of an old Ford truck and welded plates onto the stub axles and used cables and turnbuckles to mount a set of wheels to a small building in order to pull it down the road behind a tractor.
