Good point - thankyou. The dimmer is probably desirable. So I could switch the bulbs to LED and run them from 12V as you suggest, then use the converter for the display.That voltage converter will certainly work for the main temp display function.The only problem with that converter is that you can't connect 2 different inputs(12V) at the same time.You need an extra 24v output for the dimmer function(night driving) of the display.If you choose not to use the dimmer function,it will be fine.
The bulbs in the map lights can be changed to 12V bulbs or LED (BA9S).
