TreadingLight
La Liebre de la Muerte
'84 rhd (aus) hj47 troopy (2H).
I'm trying to find a wiring diagram with colors or a pinout for the connector that leads to the transmission harness (with the reverse switch, 4wd indicator, and tach signal).
It's a round, white connector, located near the firewall by the starter on the right-hand side. It is a 6-pin connector but only 5 are populated. There is a ground and ignition+ but I don't know what the other 3 are.
The transmission harness is missing and I'm looking to adapt a similar one that uses a different connector.
Can anyone tell me or point me to a diagram showing which pins correspond to tach, reverse lights, and 4wd indicator?
