Wanted HJ47 Bellhousing and Transmission Crossmember
I’ve got a Bellhousing and clutch fork from 12H-T 5spd if that works.
Won’t work. I actually have a couple of those already. Would need to be from a 40 series so the Bellhousing isn’t clocked towards the right.
Gotcha
Crossmember come in two version for the 40 series. 8/80-9/82 and 10/82+.
The L brackets depend on the frame. Interestingly the FJ45 different than the HJ47 L brackets. All other model used a third style. What frame are you using?
This is going in an LV frame, but I can make any of the above work. I can even make a late FJ40 crossmember work if that’s what I can get.
The 10/82+ crossmember was actually deeper were the front driveshaft crosses. I do not any extra 10/82+ crossmembers I do have the earlier ones. I do have HJ47 L brackets. Also have a HJ47 bellhousings. Pretty big to ship across the country.
I’ve shipped engines and hoods across the country before!
I’m interested in the Bellhousing and the earlier crossmember with HJ47 L brackets and don’t mind paying the shipping if you can box them up. Let me know what you need for them.
Haven't found the ball the clutch fork pivots on. Originally was going to return the bellhousing to the wrecking yard but telling me could couldn't pull the tachometer until it hit the pick and pull part of the yard only to find they sold to someone else I kept it. It is threaded for the tachometer sensor but the yard monkey smashed the end of the sensor pulling the engine transmission. Lucky the PTO was undamaged.
