Wanted HJ45/47 frame mounts
Michael B
Huntsville Al
I need the frame mounts that the engine will sit on. I'm installing a 2H into a 78' FJ45. I also need the rear cross member frame mounts from an early FJ60 or a very late FJ40 to support the H55 that is going in with the 2H. My email is michaelbb7@juno.com
Thanks,
Michael <><
The frame brackets are the same as the 2F equipped 40 series trucks.
What year is the 2H bellhousing from? If it's ~1985 or newer, you'll want a late 60 series crossmember with the angle to it.
Thanks Splangy! That is welcome news. The entire combo came out of an 88'-90' HJ60. I have the cross member already, but I still need the frame mounts for it.
Sounds like all you need is a set of 2H engine mounts from an HJ47. Not an easy find, but they're out there. Check the guys on Aussie eBay.
Once you get the mounts, you'll be surprised how easy it is to bolt the 60 series crossmember to the 40 series frame. You shouldn't need any other brackets.
So to re-state what I need (thanks to our friendly and knowledgeable Mud member Jeff) I'm looking for the motor bracket that goes between the block and the rubber motor mount that was used in an HJ45/47 with a 2H.
Thanks,
Michael <><
Hey Jim SOR had a set for me. You're right they were not cheap. Thanks again!
