Gretsch
So as luck would have it I went to get my 60 series inspected today. I fixed my horn this weekend to get it to pass and while that worked, it still failed inspection. The Texas Inspection Nazis failed it because the high beam indicator does not work. So now I need to get it sorted. I believe it stopped after installing the OEM Koito H4 upgrade but I didn't worry about it because it didn't matter to me. Now it does. The high beams work fine, its just the indicator on the dash that doesn't. In Texas, that's a cardinal sin apparently.
This thread seems to indicate simply adding an LED bulb in the dash will get the high beam indicator to work again with the Koito upgrade. Is this still the way to have the high beam indicator work with the Koito upgrade? Not sure how this upgrade could be OEM and not allow the indicator to light up. I am guessing a bit that my issue is due to the Koito upgrade. The bulb could just as easily be burned out, but it seems this is a common thing with the H4 upgrade so wanted to check on if there is any new info on making this work. The indicator used to work, that much I know. I am just not sure when it quit but think it was just after the Koito upgrade. Thanks in advance for any guidance here.
