I'm transitioning the 4l80 in my '66 fj40 from 2 piece Advance Adapters adapter and toyota transfer case to one piece adapter and Atlas 2. I put it all together and had a leak from the adapter. When I took it all back apart, I took pictures down to my transmission guy and he said that both of the holes top and bottom need plugs.
I don't know how it worked in the old set up, unless the adapter was just wet and was sealed better. The new adapter is metal on metal at the transfer case connection and it leaks out there. It's so rare to need these plugs, that my transmission guy doesn't have any, they are not in the rebuild kit, the ones he had were a little big.
Any idea? Source for plug, something else I can use. There's no pressure back there, just flow. This is one of the last issues to get this beauty back on the road. And I really don't to take it apart again. (lower links, skid plate support structure, rear driveshaft, transfer case, yada, yada, yada).
