help to resolve 99 model landcruiser AC malfunction (10 Viewers)
Lagos state - Nigeria
hello all, I have a 99-2000 model landcruiser and the AC is not working.
when i swich on the AC, the compressor starts and stop within 5 seconds and the AC switch light begins to blink continuosly.
The 134a Gas level was checked using guage meter by the Ac electrician and he confirmed it ok.
Please i need help to get the problem solved.
Hell NMuzj100,
I check the AC diagnostic as directed and here is what i got.
REAR FAN SWITCH and POSITION 2 on the fan speed dial are lit.
Can you look it up for me. I don't have the service manual.
thanks.
Try search I believe I have post for someone else before
LandcruiserPhil,
I have done searches and no result before posting it for help. If you have the solution, kindly help me out.
i have spent alot of money trying to get it repaired without success.
thanks
LandcruiserPhil,
thanks
Check out THIS thread
Rear Air mix damper position sensor circuit-
Check
- damper control servo motor
- damper position sensor
- harnesses between A/C amp and the same two
- A?C amp
Check
- A?C amp
NMuzj100, thanks again. i just talk to my AC tech man and it appears he doesn't know these position. can you still help me out with the circuit location?
I had the blinking A/C light it was a seized compressor that was the culprit. I scored a complete nippondenso compressor and dryer - next day air to my door for $360.00. It was not cheap to install.
The technician should be able to tell if it is a seized compressor, but then again my local guy could not figure it out so I had to take it to Toyota and they were kind enough to give me the good news in exchange for $90.
I will get back my findings after checking the all.
thanks
Check
- A?C amp
NMuzj10,
where can i get the location of the rear Air mix sensor circuit you mention?
do you have a pic of the location, servo motor and sensor?
can you send it to me if you have it?
thanks
