Last week the AC in our 99 LC started acting up. It occasionally only blows hot air and at other times it works fine.
We took it the dealership to have the AC recharged and it turned out the AC was nearly fully charged. As the technician started to wrap things up, the LC started blowing hot air for him as well. He and I traced the likely problem to the Front Air Mix Damper Control or what I like to call the “Servo Flapper Door” that is located in the passenger side footwell. Sometime this door works and sometime it does not.
I ran the diagnostic procedure for the AC panel I found in the archives and this is what it came back with.
After doing the 1 second interval blinking of all panel lights, it returns the following flashing light pattern.
First the Rear Defrost and Air Flow to Upper Body lights blink.
Next the Air Flow to Upper Body and Rear Fan lights blink.
Then the Rear Fan and Position #2 of the air flow (the one higher than the Low setting) lights blink.
After the series of these 3 blinking light sequences, it repeats again.
Can someone look up the codes in the FSM, I believe DI-624, and tell me what these light codes possibly indicate.
Thank you,
Adam
Thank you,
Adam
