Anyone here have experience on welding a cracked engine mount bracket? The crack (96-80 right side) almost looks like a separation between the original weld and the bracket at the top side of the frame, maybe even a bad weld from the factory?? I'm wondering if the entire old bead should be ground out, or just grind V between the bracket and the old bead, or weld a small plate to go over the cracked area, and type of welding is best for this repair? If MIG is best what settings should be used?? I have access to a MIG welder just no experience so may not do it myself, either way I'm trying to figure out what's the correct way to repair this. Doesn't show up in the photos but the engine and everything else is still in the engine bay. Thanks.
