We are aware that a lot of people do not install Castor correction. Mostly this is due to not having the right tools to do the job. They are then convinced that their trucks handle ok, but they are not aware of how good it can handle. We have installed the caster bushings for a lot of customers, that ran the truck without it for a while, and I have yet to meet one that did not comment on how well the truck drives. now.sleeoffroad said:![]()
Here is a drawing on how caster changes with lift. The drawings shows the locations of the frame mounted bushing and the two front bushings. The axle center line is shown, as well as the caster angle. The axle was set at 3 degrees positive caster at stock height. The axle was then dropped 2" and the new caster measurements are shown.
We initially estimated about 1 degree of caster loss per 1" of lift. This was from installing different lifts on vehicles and then having the caster measured. Due to a lot of variables involved, this was not 100% correct. From the above you can see that 1.7 degrees of change per inch is more accurate.
Also, when you measure the traditional "2 Degree" bushings from Old Man Emu, you will also see that they actually correct closer to 3.3 degrees. So they are still the correct adjustment for a 2"-2.5" lift.
Our caster plates yield 8 degrees of correction and the current control arms we sell are 11 degrees.
