Even with a small 1.5" lift you would recommend the OEM boots?That is a NEW OEM It's what you get today if you buy from Toyota. Seem I see the same on factory installed also.
If getting CVJ remains. You'll want to order with Toyota OEM boots. You'll be looking at ~$300 before core refund.
Personally I just go with NEW OEM for about ~400 ($360 plus shipping or tax).
Yeah my situation is bad enough that I am planning to replace just about everything I can because I do not trust the work that 4WP did on the truck. But really you can't blame them, they are a high turnover, shop and really they only specialize in Jeeps.Lift or no lift the CVJ standard boots will crack soon than later.
Also remember you're getting someone old worn out axle of front drive shaft. CVJ reuses the outboard tulip which axle is part of. The teeth/splines of axle will be worn, all used are. CVJ paints both ends black. This black paint needs removing , which is difficult to do from splines. The paint will make axle to hub flange very sung in most cases. But the paint will quickly wear down. Then you've play in hub flange that you do not want.
Also, groove hub flange snap ring fits in, is rounded and widen in many I've seen, and can barely hold the snap ring.
If you must go remain CVJ is said to be "top shelf". They do and excellent job with milling out the bearing surface, yielding good CV's. Toyota no-longer sell us the outboard tulip/axle. So the axles are something they can't do anything about.
Then you've what looks like aftermarket. They likely will not give you the core charge refund. So, with OEM boots and shipping you'll be in this for near the cost of new OEM.
Some have reported they like the NAPA aftermarkets.
Me I go for OEM every-time with new side seal on diff, hub flanges, cone washers and grease cap..![]()
End bevel is unimportant. What is important is a good snap ring groove with sharp 90 degree angles and good teeth (splines) of axle, that neither are worn down.So thought I would throw this out there...
One of the guys in another thread posted up some pics of the hub flange ends of his axle;
one aftermarket (CARDONE HD), and
one OEM Toyota
(post I am referring too)
The thing he noticed and wondering if others can possibly help with pics, is that on the aftermarket vs. OEM the bevel at the VERY end of the splines between the snap ring gap and the edge/end of the axle face is different. The bevel on the OEM is quite a bit more drastic (more slack or a greater angle) vs. the aftermarket being almost FLAT (steep angle). Could others with axles available take pictures!
Right... completely understand that... I am looking at this as an identification point for OEM vs. Other. Say you go with aftermarket rebuilt and are curious if they are Toyota cores. Looking to see if this would be an identification point, so like those that purchase from Detroit Axle or CVJ or another company that remanufactures/rebuilds the axles and you are just getting whatever.End bevel is unimportant. What is important is a good snap ring groove with sharp 90 degree angles and good teeth (splines) of axle, that neither are worn down.
