Help diagnosing fuel issue (2 Viewers)
Bend, OR
78' FJ40 died suddenly while I was driving down the road at about 30 mph. Coasted to a stop and couldn't restart it. Acted like it was out of gas., but, my fuel gauge showed 3/4 full and I confirmed there was gas in the tank. But no fuel in carb float. Engine will turn over for a couple seconds when I put a little gas down the carb, otherwise nothing. I pulled the fuel hose off at the fuel pump intake and blew into it (took filler cap off first). Heard bubbles gurgling from the gas tank.
Strange because she was running great -- Solid acceleration, no sputtering or stalling, etc., -- right up until the moment she died. Fuel pump only has about 4,000 miles on it.
Any thoughts/suggestions on diagnosing the issue would be appreciated.
Vapor Lock is my first thought…..how how was it and are you running ethanol laced fuel (10%)????
Do you have an original mechanical pump or electric?
Haven't noticed any signs of vapor lock. Running whatever the regular unleaded is at my corner Chevron station. It's a mechanical pump, engine and pump are off an '86 Fj60.
't notice
Fuel Filter?
Ordered a new one, should be here on Tuesday. But if it was the fuel filter would I still be able to blow bubbles into the gas tank from the fuel pump intake hose? (Asking seriously -- I don't know).
Depends on what/how filter is plugged. Filters are cheap and easy to replace, you should carry a spare.
Fuel pump can develop a hair line crack and then not pump, later it can start pumping again for a while...
$10 diode electric fuel can be plumbed is a back up or in my case that is all I run. Primes the system and starts easily
It certainly can. Don't know if this is your issue, but a cheap filter will let you know. Had the same thing happen on my FJ60. Just driving and died. Tried everything and finally had to have my wife drive over a new filter (I was near home). Replaced the newish OE one (only 5K miles on it - that's why I couldn't believe it was the filter), and off I went!
I now keep one in the spares box. I suppose it only took one tank of dirty gas, cuz I cut open the old filter and silt/dirt was baked on the media.
Good luck!
Don't buy fuel if they are filling the underground tanks. The cheaper gas station has the fresher gas most of the time. Spring and fall, warm days cold nights will condense water out of the air into yours and theirs gas tank Yellow bottle gas drier every so often helps avoid issues.
Water will plug the paper element in the filter and not let gas pass. Leave filter in hot sun for a few days and it will dry out and be as good as new.
Since you heard bubbles in the tank when blowing back from the fuel pump intake, that would suggest you have at least some amount of fuel in the tank and the fuel filter is not totally clogged.
Just curious though, how did you verify you have sufficient fuel in the tank?
If we can assume you have fuel and the filter is not clogged, you might try running a test of your fuel pump.
Pull the output line off your fuel pumpand crank the engine. If no output, pull the input line off and dip it into a container with gas in it. If still no output, you can assume a bad pump.
My 79 2F fuel pump died recently, but it dripped a bit out the weep hole as a symptom. I have also heard a failing pump can leak gas into your crankcase. So, you might check the oil level and see if you can detect the scent of gas on the dip stick.
Good luck!
Thanks -- hopefully that's all it is!
