- Thread starter
- #41
Hey there, Correct me if I am mistaken but you have the output power from the relay terminal 87 going to the pin 5 wire at the switch? Power shouldn't be coming into the switch from pin 5.Wow this is amazing to see that you came back 5 years later and updated this thread!!
Lots of good info in this thread!
I'm trying to get the heated seats turn on when I remote start my E39 528i 1998
I have the same switch with a roller wheel to adjust the heat strength.
I also only have 5 wires at the switch like another poster, not 6. But my seats are heated as well as backrests.
I did some poking with the multimeter.
With car running, started from the key in ignition, I get 12 volts on pin 3.
If I press the button for heated seats, I get 12 volts on pin 5. So I thought all I need is power on pin 5 to heat the seats?
Now what's really weird...if I remote start the car, pin 3 will have no power, but pin 1, which is switch illumination, will for some reason have 12 volts instead of pin 3. Yet the button is NOT lit.
I wired in a relay the following way.
Terminal 85 is grounded by a negative 250mA from the remote module.
The main power on terminal 30 is provided by the remote module output second ignition wire.
Now I used wire from pin 1 on the heated seat switch for terminal 86 on the relay.
So when I start the car, remote module provides constant power to terminal 30.
Negative output from remote module to terminal 85 and positive from wire on pin 1 of the heated seats energize the relay, and power from terminal 30 flow to terminal 87, which is connected to wire on pin 5 of the switch.
I double checked by starting the car this way that wire going to pin 5 on the heated seat switch has 12 volts.
My understanding is that the seat should start heating up but for some reason it doesn't.
Now I have 3 questions as a result.
- Why do I have 12 volts on pin 1 of the switch if I start the car remotely, and nothing on pin 3. However if I start the car with a key, it's the opposite (pin 3 has 12 volts and pin 1 has 0)
- Why are the seats not heating with my setup, I.e. power going to wire 5 of the heating switch.
- Should I just drop the relay and connect the power wire out of the remote starter directly to the wire on pin 5 of the heated seat switch?
The way I wired my switch was also with a relay. I have fused battery power going to relay terminal 30. The output 87 terminal of the relay goes to the heated power input for the seats. Pin 1 on the switch gets power only when the other switches are illuminated, that gets power from a wire that only comes on when the lights are on. Pin 3 at the switch gets power from a ignition activated wire (can me any power source you want really). Pin 4 is grounded so the illumination at the switch works. Now pins 5 and 6 (5 if you just have 5 wires) is the output from the switch, that goes to terminal 86 at the relay. So when the switch wants to activate the seat heat, it activates the relay to send power to the heating elements. Pin 2 is hooked up to the NTC terminal on the seats.
Does that clear anything up?
