HDJ62 (4 Viewers)
Santa Barbara
Hey Mud -
I just picked up a new project.
The truck started life as an 1986 HJ61 in NZ. It received a 1HD-T + 4speed auto swap before making the journey over to the US in the late 00's. A tree fell on it and the PO did a body swap with an '89 FJ62 (US spec). While he was putting it back together, his house (and garage) burned down in a fire. Brutal.
Sooo, now I have a late model LHD 60 series with a 1HD-T in it, but there are definitely some missing components to be sourced to get it running. Listing out a least some of the items I am in search of that I could use some help finding, in case folks have extras they are looking to sell:
  1. 12V Starter.
  2. Battery Trays (ordered SS from SS-trays.com)
  3. Injector pipes (ordered from cruiser parts, but still waiting for them to ship...)
  4. Fuel filter assembly (I got some recs in another thread to go with Racor rather than factory or to explore a dual, in line set up from a 79 series. I will likely make sure the engine spins with the injectors pulled before I invest in fuel filter assembly). I will also need to figure out how to get the fuel lines from the passenger side of the engine bay to the DS side of the engine bay.
  5. Air Conditioning compressor
  6. 12V alternator (EDIT: seems like this might actually be 12V from the factory, need to check when I am with it next)
  7. Vacuum reservoir. I didn't see one in the engine bay. I know these are under the body on my 40 series trucks, but I assume that might have not made it off the HJ61 body.
  8. Air Box (I picked one up from @Workhorse when I was out in CO recently. Amazing rigs he has in his garage. Jealous! Thanks again, @Workhorse -- its the nicest looking part on the truck, at the moment.)
There will be a laundry list of more generic 60 series components I will likely also need, eventually, but prioritizing the power train for now to validate I have something worth working on.
Including a few basic photos. Haven't really had an opportunity to clean it up and take good photos yet. Super stoked though! This is my first 60 series after a number of 40s, 80s and a 70.
Cheers!
Glad to help and am looking forward to seeing this in person once completed.
you’ll love the 1hdt in the 60! i have one in my 62 with a h55 and it’s amazing to drive!!
Sweet! Can't wait. I've had a HD in an 80 series and loved it. Pretty excited to get this rolling.
I am still waiting on CruiserParts to ship the injector pipes. Wondering what they are not telling me. I have a message out to Terrain Tamer.
Still looking for a 12V starter, too. For now, just planning on rotating the motor by hand with the glow plugs pulled. Planning to swap the oil & oil filter and run the diesel fuel directly from a fresh aux tank for now. Turn a few times by hand with plugs pulled to get the oil pump gear turning and get the top end lubricated.
With old gas engines, I've put oil in the cylinders before a first attempt at spinning the engine by hand. Is that necessary/advised for diesels? Fogging oil? 15-40W?
Cheers
I found some useful info in this thread that describes the Yanmar 6LP generic part number compatibility and am going to order an inexpensive 12V starter from amazon to get spinning! Still looking for an injector pipe source.
Spent the day yesterday cleaning out some space at my uncle's property so I have a place to work on this thing!
Nice rig! Copy with the Yanmar amazon starter - Im running one on my 1hz and its good.
did you check Partsouq for the injector pipes? They had new stock for 1hz when I was building mine.
For an Alt, Im using on out of a 93 FZJ80, again Im running a 1hz but I think the front ends of the motors are very very similar.
For a vacuum reservoir I got a generic from Jegs or Summit.
Im running a Racor 445 with either 10 micron or 2 micron filters, its probs a little overkill but it has an integrated primer which is nice and filters arent too hard to come by.
If you are not certain about the history of the motor now would also be a good time to at least pull and inspect or replace the big end bearings (BEBs).
Sweet - thanks for all of the info. I just got my starter. Looking forward to getting this thing moving soon. Copy on the Racor 445. @PBcuiser do you mind sharing a few photos of how you laid out your engine bay? Fuel filter and vac reservoir are the two items that are top of mind, but it would be super useful to reference when placement questions inevitably come up.
Not the best pic but you can see fuel filter in upper right and vac reservoir in lower left. Pic is taken from driver side fender. Happy to provide more info as you get further along!
Truck is now situated at its new work space for the next few months.
I got the new starter installed as well as the battery tray.
Plan to remove glow plugs and spin by hand this week sometime.
Hi All -
I changed the oil and attempted to pull the glow plugs to drop some oil into the cylinders. I found access to be a little tricky, so might have to move the cross over pipe to get in there.
I spun the crank with a breaker bar and it rotated smoothly. I had a look inside the valve cover via endoscope and it looks like the valve train is lubricated nicely.
Do folks think it is worthwhile to go through the effort to remove the GPs and lubricate the cylinders before I try to crank it for real?
I need to make a new battery to starter cable. I have some 2/0 welding cable left over from another project that I will likely use. Same for the ground wire to the frame.
It's clear to me where the starter wire connects from the ignition switch (black and red below) though it needs to get to the other side of the engine bay. Will need to figure out routing. There are a number of other connectors near the starter switch that I need to identify.
Any recommendations on what factory harness wires from a '89 62 with 3FE would be useful to bring over over to the IP shutoff solenoid? Something that is one when ignition switch is in running or start position.
I suppose I need to figure out the neutral safety switch wiring, as well.
Cheers,
Austin
I am imagining that the harness on the other side of the engine bay (pictured below) is for the alternator connection. Seems like there will be a number flipped harness locations relative to actual component location on the engine block as it's an LHD body with a RHD configured 1HD-T.
Oil does not belong in the cylinders and if the engine is free, there is no need to add it. It is only used in case of a low compression reading to load the piston rings and potentially identify them as the source of compression loss.
If the engine has been standing for a long time I would crank it with the injection pump fuel solenoid lead removed and the glow plugs out to bring the oil pressure up. Either read the dashboard gauge or use a proper oil pressure tool.
Unlike proper automotive heavy gauge battery cable, welding cable is very flexible so make sure it is well secured.
I got the starter spinning. But haven't been able to actually do so "properly" using the starter wire from the chassis wiring harness.
I suspect the issue is the neutral safety switch circuit. Four of five connectors from the chassis found their proper homes on the trans/t-case wiring harness, but this one did not
I think it might be the t-case neutral circuit based on the wiring diagram I have, but I guess I am not sure why the affiliated component on the t-case side would not be present. The auto is from New Zealand and was mated to a 1HD-T, so not sure what the exact model number would be on it. I can look at the housing when I am next under the truck.
In any case, I don't think that the t-case neutral would be in the neutral start switch circuit, so I wouldn't think its exclusion would be disruptive.
In any case, I am planning to add some coolant and hoses to make a little closed loop circuit for cranking, install the fuel lines to a temporary small fuel tank, wire the solenoid temporarily and see if I can get it to turn over this weekend.
Sorted out the neutral safety switch such that the key now turns the starter.
Validated good oil pressure with a multi-meter. Seems the gauge and the sending unit are not properly synchronized.
Now working on fuel. I've had trouble finding the 3-pos connector for the IP. It's available here, but $100 delivered seems insane. I will likely just wiring something up temporarily while I figure out another solution. Chinese vendors offer them at like $0.50/piece but you have to order 10 and wait like 30 days. Idk if people have other recs. The New Zealand harness burnt up in the fire, according to the PO.
The injector inlets have sat uncovered for the last 8(?) years so there is some oxidation/dust that is visible. The "right" solution would be to pull the injectors and have them reverse flowed and cleaned and potentially rebuilt, but if that is the inevitable outcome regardless I wonder if I might as well see if it fires up before I spend another month waiting for injectors to come back.
I will rig something up with IV tubing and a shop vac such that I can pull out all of the accessible gunk.
Left tail light lens that was warped due to heat from the fire. Indication as to how close the flames got. Fortunately as far as it got.
Here's two sources for Sumitomo connectors that might have what you are looking for:
I got the truck started!
After I figured out the glow plug wiring and bleeding the injector pipes it fired right up. Runs smoothly.
Now I need to figure out fuel, coolant system, ATF cooling, brakes, and finish off electrical.
I’ve been chasing down fittings for the ATF cooling system. Found 14x1.5 -> 3/8 barb connectors for the radiator side and 16x1.5 -> barb for the transmission pipe side. Hopefully that works.
I am missing the angle brackets on the side of the radiator that mount to the engine bay, also missing the radiator cowling. They don’t seem to be available on partsouq. Any ideas?
Cheers,
Austin
