Hand Throttle Part Number (1 Viewer)
Liberty, UT
Quick Question
I have been trying to pick up a hand throttle from the local Toyota dealer. Luckily the guys out here know what an FJ60 is, unfortunately they can't seem to locate the hand throttle.
I've looked through the boards here and have been unable to find the exact part number here either.
I was wondering if anyone had the number for the fj60 hand throttle or could tell me where I need to go to find it.
Thanks
Buffalo Grove, IL
Also, before you buy it, make sure your accelerator pedal have the cable attachment bracket on it or you will need to get that as well. I thought that some of the earlier 60s didn't have it.
Pollock Pines,CA
local bike shop. about $5 for a thumb shifter and cable that they took off a stock bike to upgrade. hook directly to your carb linkage. done. no point in spending all that money
rchalmers3
I speak Toyota
Playas de Nosara, Nicoya Peninsula, Costa Rica
My '83 FJ60 did not have the tab on the pedal arm like you have mentioned. I had access to a replacement part that had the tab, so I used that. If cost is a consideration, it would be a 10 minute job to tack on the tab, drill a hole and slot the tab to receive the cable.
Rick
Ruston, LA
I just took a look at my peddle out of curiousity; couldn't you just slap on a throttle cable for a mower or something like that? Sure looks real simple unless I'm missing something
Colorado
I'm going to be replacing mine, what's the attachment behind the dash? I can't tell by feeling but seems like a large plastic clip of some kind.
the NJ word..
The parts needed for the OEM lock are-
1. The hand throttle assembly
2. The nut to tighten the TA from the back to the dash
3. The bracket that bolts under the dash that the end of the throttle assem. clips into
4. A white plastic doodad that goes around the cable of TA and clips into the square hole on top of the accelerator pedal.
the NJ word..
Whidbey Island, WA
Another vote for the bike brake handle. This thing has been far more useful than that knob on the dash ever was.
Got the handle for free and the cable kit was $5 at Wal-mart
Tony
