So I took the truck back out this am. If I double or triple clutch, I can get it to go back into second, particularly if I rev it a bit between clutching. Maybe it is a top plate issue affecting fork alignment. I did take the top plate all apart during the rebuild, which was stupid as it was a pain and I really didn't do much other than clean it up. I have to believe that if it was a synchro/gear issue, I couldn't get it in or out of second at all. Going from 1 to 2 is no problem at all and even getting into first is pretty easy with a bit of speed. Could things just need to loosen up after the rebuild? It almost felt like it was getting better.
is this H42 a early style type with a cast iron 2 piece shift tower / top plate / plates assy. ?
or
a later 1piece ALL Aluminum Shift Tower assy. ?
also ,
please photos , and good crisp clear ones close up of the shifter cane receiver hole in the top plate / tower , focus in a photo of EACH of the 2 dowel pins inside the bore hole itself please .....
there is a very unique technical topic we need to evaluate , confirm and verify regarding the 2 small dowel pins i detail into above ....
after you report back these needed tech. photos , ill elaborate more as to why and stuff , but un-necessary speculation ramble on , can be a distraction here so ill wait to chatty matty up this topic then verse now ...
also :
- did u replace with NEW OEM parts the shifter cane retainer CUP thing , and the big spring itself in this focus point area im talking about ?
if NOT , ?
post photos or BOTH of the Twist-Lock female dowel pin retainer cut outs on the cane reciever tower too , that physically hold the shift cane in place please
this ALL related to one another topics ..fyi
if you don't understand what im referring to , don't be shy speak up , this is OK , ill post parts diagrams if necessary
matt
